[GRASS5] GRASS5.7: trouble converting shapefile to postgis
with v.convert
Moritz Lennert
mlennert at club.worldonline.be
Fri Dec 5 11:38:44 EST 2003
Radim Blazek said:
> On Thursday 04 December 2003 19:17, Moritz Lennert wrote:
>> Hello,
>> I have a shapefile registered in GRASS5.7:
>> GRASS 5.7.-cvs:~ > g.list vect
>> vector files available in mapset mlennert:
>> communes.shp
>> I can display and query this file without any problems.
>> It is connected to a dbf file:
>> GRASS 5.7.-cvs:~ > v.db.connect -p communes.shp
>> Vector map <communes.shp> is connected by:
>> field <1> table <communes> in database </home>
>> through driver <shp> with key <shp_fid>
>> Following the tutorial, I tried to store this map in PostGIS format:
>> GRASS 5.7.-cvs:~ > v.database driver=pg database="dbname=digit_belgium"
>> GRASS 5.7.-cvs:~ > v.convert input=communes.shp output=communes
>> but I got the error message: "ERROR: Input vector was not found."
>> What am I doing wrong ?
> v.convert converts old GRASS vector files (GRASS 4.0,5.0) to 5.1/7 format.
> v.database is used to set the database for attributes.
> If you want to write a vector in PostGIS format, you have first set
> the output vector format to PostGIS either in
> v.format -> output format -> PostGIS
> or by g.gisenv:
> g.gisenv store=mapset set=GV_FORMAT=POSTGIS
> set=GV_PGIS_DATABASE=host=liptakov,dbname=cimrman,user=jara
> Once you set vector format to PostGIS, all new vectors are written to the
> database.
> Attributes are by default written to dbf files, so until you set also
> you get geometry in Postgres and attributes in dbf, isn't it funny?
I did all these steps, just following the tutorial, but the problem was
the usage of v.convert. May I conclude that the description in the
tutorial at
http://grass.itc.it/grass51/tutorial/geom_storage.html#PostGRASS is wrong
then ?
> To convert the vector you can run g.copy for example, but that is not what
> you want
> as communes will be polygons and you have to clean such vector first.
> I would recommend v.in.ogr as it does all the cleaning. See the statistics
> about
> areas at the end.
So you would recommend this rather than just using the shp2pgsql program
that comes with postgis ?
Moritz
