[GRASS5] Re: [GRASSLIST:1962] Re: (DY)LD_LIBRARY_PATH
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Dec 8 12:21:36 EST 2003
On Mon, 8 Dec 2003, Glynn Clements wrote:
> Paul Kelly wrote:
> > I looked again and realised it would be better to put this stuff into the
> > grass57 startup script as it's already generated in this way. I also found
> > a bug in which the GRASS_PERL variable wasn't substituted as it was in
> > init.sh, so I moved it into grass57.
> That's the wrong fix. The grass57 script should simply set GISBASE
> then run Init.sh. All of the actual work should be in one place. The
> correct fix is to fix the Makefile to perform the substitution in the
> correct file (init.sh -> Init.sh).
OK I've done this now. I see now that this file was already being run
through a sed command anyway. The comments in grass.src and the special
suffix had confused me.
