[GRASS5] Grass 5.3 on Mac OSX
Glynn Clements
glynn.clements at virgin.net
Tue Dec 9 07:21:09 EST 2003
Markus Neteler wrote:
> > > This way, a tarball I create wouldn't overwrite someone's existing
> > > grass 5.0.x files when untarred.
> > I definitely think the 5.3 startup script should have a different name
> > from the 5.0 one and unless there are objections I will see that it is
> > changed before the 5.3.0 release is made.
> Let's change (also gmake53 and gmakelinks53).
gmake5 and gmakelinks5 shouldn't be installed; they can always be run
from the bin.<arch> directory.
Glynn Clements <glynn.clements at virgin.net>
