[GRASS5] 57 with postgres on OSX
Kirk R. Wythers kwythers at umn.edu
Mon Dec 15 12:18:36 EST 2003
Here is a compile error that I occurs when trying to build 57 (latest
snapshot) with postgresql on OSX (the build finished with no errors if
I simply remove the lines:
    --with-postgres-includes=/sw/include/postgresql \
    --with-postgres-libs=/sw/lib \
and add the line:
    --without-postgres \
to the config script.
I would very much like to be able to post 57 binaries with postgres
support, but I could use some feedback from more experienced builders
as to how to resolve this issue. In an earlier email Markus wrote:
"Your problem looks like a configure issue.
In ./db/drivers/postgres/Makefile
CRYPTLIB = -lcrypt
is hardcoded. Maybe this should go elsewhere into Platform.make
Markus"
Markus, Can you (or anyone else) expand on this idea? I just don't
follow.
gcc -I/Users/kirkw/grass/grass57_exp_2003_12_13/include
-I/Users/kirkw/grass/grass57_exp_2003_12_13/dist.powerpc-apple-
darwin7.0.0/include -I/usr/X11R6/include -I/sw/include -g -O2  -Wall
-Wconversion -Wno-implicit-int  -I/usr/X11R6/include -I/sw/include
-I/sw/include/postgresql -I/sw/include -I/sw/include
darwin7.0.0/include \
         -o OBJ.powerpc-apple-darwin7.0.0/main.o -c main.c
         -o OBJ.powerpc-apple-darwin7.0.0/parse.o -c parse.c
         -o OBJ.powerpc-apple-darwin7.0.0/select.o -c select.c
gcc -g -L/sw/lib
-L/Users/kirkw/grass/grass57_exp_2003_12_13/dist.powerpc-apple-
darwin7.0.0/lib  -o
darwin7.0.0/driver/db/pg OBJ.powerpc-apple-darwin7.0.0/cursor.o
OBJ.powerpc-apple-darwin7.0.0/db.o
OBJ.powerpc-apple-darwin7.0.0/describe.o
OBJ.powerpc-apple-darwin7.0.0/driver.o
OBJ.powerpc-apple-darwin7.0.0/error.o
OBJ.powerpc-apple-darwin7.0.0/execute.o
OBJ.powerpc-apple-darwin7.0.0/fetch.o
OBJ.powerpc-apple-darwin7.0.0/listdb.o
OBJ.powerpc-apple-darwin7.0.0/listtab.o
OBJ.powerpc-apple-darwin7.0.0/select.o -L/sw/lib -lgrass_dbmidriver
-lgrass_dbmibase -lgrass_sqlp -lgrass_dbstubs -lgrass_dbdialog
-lgrass_gis -lgrass_datetime  -lintl -lgrass_datetime -lpq  -lcrypt
-L/sw/lib/tcl8.4 -ltk   -ltcl  \
          -lz
ld: can't locate file for: -lcrypt
make[3]: ***
[/Users/kirkw/grass/grass57_exp_2003_12_13/dist.powerpc-apple-
darwin7.0.0/driver/db/pg] Error 1
make[2]: *** [subdirs] Error 1
make[1]: *** [subdirs] Error 1
make: *** [default] Error 1
Kirk R. Wythers	                                     tel: 612.625.2261
Dept. of Forest Resources                 fax: 612.625.5212
University of Minnesota      email: kwythers at umn.edu
