[GRASS5] [bug #2252] (grass) s.vol.rst segfaults
Request Tracker grass-bugs at intevation.de
Tue Dec 16 12:56:08 EST 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=2252
Subject: s.vol.rst segfaults
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: 5.0.2
s.vol.rst gives a segfault when loading WIND3 or DEFAULT_WIND3 if their format
isn't exactly right or if the file being loaded is empty.  I recognize that an empty
configuration file isn't the best thing to have, but a segfault isn't the best way to
deal with it either.
I believe that this problem is in G3d_readWindow() (in g3dwindowio.c), but I
haven't played with it enough to confirm this.
Also, on the subject of s.vol.rst, it would be nice to put in an exit(1) or some such
if G3d_readWindow() fails (returns 0) at the start (line 189 in main.c): I can't think
of anything good which can come from s.vol.rst continuing without a region
defined.
-------------------------------------------- Managed by Request Tracker
