[GRASS5] distclean error
Kirk R. Wythers kwythers at UMN.EDU
Tue Dec 23 13:03:09 EST 2003
And another thing. This error also seems to be messing up my 57 builds.
See below. I did re-name the directory that I am building it. Is that
part of the problem?
Thanks,
Kirk
gcc -I/Users/kirkw/grass5_dev/grass57_exp_cvs/include
-I/Users/kirkw/grass5_dev/grass57_exp_cvs/dist.powerpc-apple-
darwin7.2.0/include -I/usr/X11R6/include -I/sw/include -g -O2  -Wall
-Wconversion -Wno-implicit-int  -I/usr/X11R6/include -I/sw/include
darwin7.2.0/include \
         -o OBJ.powerpc-apple-darwin7.2.0/table.o -c table.c
table.c:97: warning: return type defaults to `int'
table.c: In function `db_driver_drop_table':
table.c:115: warning: passing arg 3 of `SQLTables' with different width
due to prototype
table.c:115: warning: passing arg 5 of `SQLTables' with different width
due to prototype
table.c:115: warning: passing arg 7 of `SQLTables' with different width
due to prototype
table.c:115: warning: passing arg 9 of `SQLTables' with different width
due to prototype
table.c:137: warning: passing arg 2 of `SQLFetchScroll' with different
width due to prototype
table.c:138: warning: passing arg 2 of `SQLGetData' with different
table.c:138: warning: passing arg 3 of `SQLGetData' with different
table.c:140: warning: implicit declaration of function `strcmp'
table.c:160: warning: passing arg 1 of `SQLGetDiagRec' with different
table.c:160: warning: passing arg 3 of `SQLGetDiagRec' with different
table.c:160: warning: passing arg 7 of `SQLGetDiagRec' with different
table.c:161: warning: int format, SQLINTEGER arg (arg 6)
gcc -L/usr/X11R6/lib -L/sw/lib
-L/Users/kirkw/grass5_dev/grass57_exp_cvs/dist.powerpc-apple-
darwin7.2.0/lib  -o
/Users/kirkw/grass5_dev/grass57_exp_cvs/dist.powerpc-apple-darwin7.2.0/
driver/db/odbc OBJ.powerpc-apple-darwin7.2.0/connect.o
OBJ.powerpc-apple-darwin7.2.0/cursor.o
OBJ.powerpc-apple-darwin7.2.0/db.o
OBJ.powerpc-apple-darwin7.2.0/describe.o
OBJ.powerpc-apple-darwin7.2.0/driver.o
OBJ.powerpc-apple-darwin7.2.0/error.o
OBJ.powerpc-apple-darwin7.2.0/execute.o
OBJ.powerpc-apple-darwin7.2.0/fetch.o
OBJ.powerpc-apple-darwin7.2.0/listdb.o
OBJ.powerpc-apple-darwin7.2.0/listtab.o
OBJ.powerpc-apple-darwin7.2.0/main.o
OBJ.powerpc-apple-darwin7.2.0/select.o
OBJ.powerpc-apple-darwin7.2.0/table.o -lgrass_dbmidriver
-lgrass_dbmibase -lgrass_dbstubs -lgrass_gis -lgrass_datetime  -lintl
-lgrass_datetime -lodbc   -lz
ld: warning suggest use of -bind_at_load, as lazy binding may result in
errors or different symbols being used
symbol _locale_charset used from dynamic library
/sw/lib/libiconv.2.dylib(localcharset.o) not from earlier dynamic
library /sw/lib/libintl.1.dylib(localcharset.lo)
postgres
Makefile:11: *** missing separator.  Stop.
make[2]: *** [subdirs] Error 1
make[1]: *** [subdirs] Error 1
make: *** [default] Error 1
truffula:~/grass5_dev/grass57_exp_cvs kirkw$
On Dec 23, 2003, at 9:30 AM, Kirk R. Wythers wrote:
> I just did a cvs up on the grass57 source. Now when I " make clean" or
> "make distclean" I get the error:
> /bin/sh -c "find . -name 'OBJ*' -exec rm -rf {} \; 2>/dev/null ; true"
> rm -rf
> rm -f
> rm -rf
> rm -f
> drivers
> dialog
> rm -rf
> rm -f
> dbf
> rm -rf
> rm -f
> odbc
> rm -rf
> rm -f
> postgres
> make[2]: *** [cleansubdirs] Error 1
> make[1]: *** [cleansubdirs] Error 1
> make: *** [clean] Error 1
> Does this look familiar?
