[GRASS5] Almost there...
Markus Neteler neteler at itc.it
Sat Feb 1 05:23:56 EST 2003
On Sat, Feb 01, 2003 at 03:00:05AM +0000, Glynn Clements wrote:
> The best approach is to start with a Gmakefile from a similar module,
> preferably one which uses the same libraries, and ideally one which is
> under active development (so that the Gmakefile is more likely to be
> up-to-date).
If you don't want to download the full source code for that,
you can simply go to the CVS page on the GRASS web site and
use the CVS HTML interface. This enables you to download individual
files from CVS and/or tar balls from (sub)directories.
Markus Neteler
