[GRASS5] Projection programs
Bob Covill bcovill at tekmap.ns.ca
Mon Feb 3 09:09:32 EST 2003
Paul,
I have latest CVS GRASS and have found a couple of projection programs
are not quite working. I discovered the problem when using m.ll2db which
converts to and from GRASS database and Lat. Long. coordinates. When I
run the program I get the following error ...
cannot initialize pj
cause: major axis or radius = 0 or not given
The problem is with how the "ll" projection is initialized, namely ...
parms_in[0] = '\0';
pj_get_string(&info_in, parms_in);
If I change this to a better qualified initialization such as ...
sprintf(ll_buf, "+proj=ll +ellsp=wgs84"); /* +datum also works with
current setting */
pj_get_string(&info_in, ll_buf);
it works fine. This problem has implications with other programs such as
m.proj(2), and v.in.gshhs. There may be others with this type of
initialization.
You seem to be a few steps ahead on the PROJ stuff. Should the code be
fixed (m.proj seems to be on the chopping block) or do you have other
suggestions?
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
