[GRASS5] TAGS file?
Glynn Clements
glynn.clements at virgin.net
Sun Feb 2 23:42:50 EST 2003
Jeff D. Hamann wrote:
> Is there a TAGS file for the GRASS source code anywhere?
There isn't one included in the source tree.
I'm not sure that a global TAGS file would be a good idea; it's better
to create files which are relevant to the code on which you are
working (i.e. for the module itself and the libraries which it uses).
> Does anyone use one?
I occasionally create TAGS files for relevant parts of the tree.
Glynn Clements <glynn.clements at virgin.net>
