[GRASS5] Changes between 5.0.1 release and current CVS head
Glynn Clements
glynn.clements at virgin.net
Mon Feb 3 15:28:07 EST 2003
Paul Kelly wrote:
> > 2002-10-07 22:13 glynn
> > * src/raster/r.in.gdal/gdalbridge.h: Add declarations for
> > GDALGetDriver{Short,Long}Name, GDALGetDatasetDriver [fix submitted
> > by Paul Kelly]
> > IMHO yes.
> This probably should have been on the release branch already.
> r.in.gdal doesn't compile on IRIX otherwise.
AFAICT, this part is tied to the changes which I labelled "AVHRR" for
src/raster/r.in.gdal/main.c. Both sets of changes have to be made
together, otherwise it won't compile on anything (unless you use
--with-gdal).
The IRIX-specific problem was due to:
#if defined(__unix__)
This has since been changed to:
#if defined(__unix) || defined(__unix__)
This change made it into 5.0.0.
I'll leave the projection stuff out for now.
Glynn Clements <glynn.clements at virgin.net>
