[GRASS5] fifo configure
Wallace, Beverly T beverly.t.wallace at lmco.com
Mon Feb 3 20:05:29 EST 2003
Grass Developers,
I recently installed GRASS 5.0.0.  I configured it for fifos and had two
problems:
(1)  Configuring with "--enable-fifo" is not enough, "--disable-socket" is
also needed.  Is that how it is supposed to work?  The configure help says
that "--enable-fifo" will use the FIFO XDriver instead of sockets, which
suggests that sockets are automatically disabled.
(2)  The monitorcap file did not work until I added full paths.
Bev Wallace
Lockheed Martin, Sunnyvale, CA, USA
