[GRASS5] Changes between 5.0.1 release and current CVS head
Markus Neteler
neteler at itc.it
Tue Feb 4 07:22:09 EST 2003
On Mon, Feb 03, 2003 at 08:17:28PM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > > > html/index.html
> > > > html/searchhtml.html
> > > > index2.html -> index.html
> > > Don't know.
> > Yes (index2.html doesn't exist any more on the web)
> If the URLs are meant to refer to the GRASS website, they should be
> absolute URLs. Bear in mind that these files are installed into
> $GISBASE/documents; relative URLs should only be used when the target
> is also in $GISBASE/documents.
> I think that I was getting confused with the following (from
> html/index.html):
> <a href="../nviz/index.html">nviz visualization tool tutorial</A>
> This URL is wrong for a local copy of index.html (".." doesn't make
> any sense from the top-level directory); it should be:
> <a href="nviz/index.html">nviz visualization tool tutorial</A>
> If the GRASS website is layed out differently, then the file should be
> pre-processed for use on the web site.
I agree that the current file organization is a bit messy.
If someone updates the docs as desired/proposed, I'll fix the cronjobs
on grass.itc.it subsequently.
> > > > src/CMD/generic/gmake.sh
> > > > Allow C++ files (incomplete)
> > > Don't know.
> > Wasn't the logic fixed recently?
> It was "fixed" so as to be harmless (the first attempt broke the case
> when the .c file was generated, e.g. by lex/yacc). However, it's far
> from correct: C++ files should use $(CXX) instead of $(CC), and
> $(CXXFLAGS) instead of $(CFLAGS). This would require changes to
> several other files (configure[.in], head.in).
> See my previous message:
> From: Glynn Clements <glynn.clements at virgin.net>
> Subject: Re: [GRASS5] C++ compilation
> Date: Thu, 23 Jan 2003 21:43:40 +0000
> Message-ID: <15920.25100.848724.42087 at cerise.nosuchdomain.co.uk>
Ok, but if harmless we could upload it to enable people to compile
r.terraflow.
> > > > src/general/init/grass.src
> > > > Trap signals
> > > Don't know.
> > I have added this to avoid that GRASS continues when the user
> > hits CTRL-C while defining a new location. I never liked that
> > GRASS continues and generates a broken new location, when
> > I try to stop the create-location procedure.
> > So, IMHO yes.
> Doesn't this belong in Init.sh, then? That's where the code in
> question is.
Maybe. But it already works. So probably we should add is additionally
to Init.sh?
The line in question is:
trap "echo 'User break!' ; exit" 2 3 9 15
> > > > src/imagery/i.ortho.photo/photo.rectify/write.c
> > > > Error messages
> > > No.
> > 2002-09-24 14:57 markus
> > * src/imagery/i.ortho.photo/photo.rectify/write.c: changed write
> > error to strerror(errno) as suggested by Glynn
> > Is this dangerous? Of yes, it should be also reverted in HEAD.
> Two issues: Regarding the first message, I don't know how portable
> strerror() is; older BSDs don't have it.
> Regarding the second, the message is over 80 characters; also, you
> could reasonably argue for adding the same message to every module
> which writes files (i.e. most modules), which is really an argument
> for putting it lower down. Also, permissions definitely aren't an
> issue, as they are checked upon open and not upon write.
Ok, sounds as if it should be reverted.
> > > > src/libes/gis/ellipse.table
> > > > Enable "sphere"
> > > Yes.
> > Note that "sphere" doesn't seem to work (will have to retry).
> Please do.
Will do.
Markus
