[GRASS5] Working MicroStation DGN format
GFernandez-Victorio at IGAE.minhac.es
Wed Feb 5 09:58:09 EST 2003
> -----Original Message-----
> From: Ronaldo Oliveira [mailto:ronaldo_ap_oliveira at yahoo.com.br]
> Sent: Monday, February 03, 2003 6:29 PM
> To: grass5 at grass.itc.it
> Subject: [GRASS5] Working MicroStation DGN format
> I'm working with GRASS 5 and I need to
> insert/view/open dgn file format from MicroStation J
> by Bentley. But, GRASS 5 only import/work dxf file
> format. Is there an option to work with dgn in GRASS
> 5, without to change/convert to dxf format?
There used to be v.in.dgn:
v.in.dgn - Imports Microstation DGN vector files.
but seems to not be compiled by default. The readme for
that command, says:
v.in.dgn requires dgn library and header files
written by Frank Warmerdam.
See http://www.remotesensing.org/gdal/index.html.
Maybe you should use gdal.
