[GRASS5] r.in.gdal  and colors
    Frank Warmerdam
    warmerdam at pobox.com
    Wed Feb  5 22:30:51 EST 2003
Eric G. Miller wrote:
> On Wed, Feb 05, 2003 at 10:53:17AM -0500, Russell Nelson wrote:
>>Moritz Lennert writes:
>> > Thanks that did it. Don't understand why I have to go through grey to get
>> > colors, but oh well...
>>Makes no sense to me either.  If r.in.gdal splits an image up into R,
>>G, and B, then it ought to set the colormap for those rasters to
>>grey.  When would you ever want it otherwise??
> AFAICT, r.in.gdal only writes a color map if the image source has a
> color map.  This is not usually the case for RGB type images.
> The default color map in GRASS is a rainbow...
Eric / Russell,
Do you or others who get the Zen of GRASS better than I think r.in.gdal ought
to be writing a greyscale colortable for imported files without a colormap?
Should it only do this for multiband images?  Only for 8bit images?
I would be happy to make changes, but I don't want to imply color tables where
they don't exist unless it is widely accepted as the correct thing to do.
Best regards,
