[GRASS5] CygWIN: compilation of current CVS HEAD?
Glynn Clements
glynn.clements at virgin.net
Wed Feb 5 21:49:56 EST 2003
Markus Neteler wrote:
> today we tried to compile the current CVS HEAD on Win2K/Cygwin
> and faced some strange problems happening in
> src/CMD/generic/gmake.sh
> We used
> sh -x /usr/local/bin/gmake5
> to see the problem.
> Probably it is related to the latest change for .cc files?
> Problem:
> The 'sort -u' in row 285 says "file not found".
Is GNU "sort" installed? Does it appear first in the path?
Otherwise, you may end up running the DOS sort.exe, which will try to
sort the file called "-u", and complain.
Glynn Clements <glynn.clements at virgin.net>
