[GRASS5] [bug #1634] (grass) d.mapgraph: survive redraw?
Glynn Clements glynn.clements at virgin.net
Thu Feb 13 03:45:51 EST 2003
Request Tracker wrote:
> It would be nice if someone could figure out how to get d.mapgraph to
> survive a redraw or zoom.
> Currently the call to D_add_to_list(G_recreate_command()) is commented
> out, as the program can take input from stdin, which doesn't get saved
> to the print list.
> instead, i.e. add to the print list only if input comes from an actual
> disk file.. better than nothing anyway.
> any ideas? prepend the stdin input and some pipes to the d.mapgraph
> command line string?
d.text has the same problem; it solves it by redirecting input from
the temp file to which stdin is copied:
	max_buff = G_malloc(strlen(wind_file_name)+strlen(G_recreate_command())+4);
	sprintf(max_buff, "%s < %s", G_recreate_command(), wind_file_name);
	D_add_to_list(max_buff);
	G_free(max_buff);
However, d.mapgraph processes stdin directly, so you would have to
add code to store the data read from stdin (although you would have to
do this however you solved the problem).
Ultimately, the D_add_to_list() concept is fundamentally flawed. There
will always be cases which don't work.
Glynn Clements <glynn.clements at virgin.net>
