[GRASS5] CygWIN: MinGW compilation of R/GRASS interface
Glynn Clements
glynn.clements at virgin.net
Fri Feb 14 05:07:48 EST 2003
Roger Bivand wrote:
> Grateful for any suggestions about where to look!
My initial suspicion is that MinGW's versions of the Unix I/O
functions (open, creat, read, write) perform LF<->CRLF conversion.
On Unix, these functions don't do any conversion.
On Cygwin, they may or may not do conversion, depending upon more
factors than I care to list here. However, if conversion gets
performed, you get a corrupted database.
There is some stuff at the bottom of MinGW's fcntl.h (_fmode,
_setmode()) that looks as if it might be relevant. However, I don't
have any documentation for MinGW, only the headers.
Glynn Clements <glynn.clements at virgin.net>
