[GRASS5] CygWIN: MinGW compilation of R/GRASS interface
Roger Bivand
Roger.Bivand at nhh.no
Tue Feb 18 09:26:04 EST 2003
On Tue, 18 Feb 2003, Glynn Clements wrote:
> Roger Bivand wrote:
> > I've submitted GRASS_0.2-2 to CRAN, thanks for your help. One problem that
> > I hit is that strlen() in G_store() usually crashes (MinGW and gcc RH
> > 2.96) when passed a NULL string - a test might be an idea anyway in
> > libes/gis/store.c.
> If you know of any specific cases where NULL might be passed to
> G_store(), please report them, as they may indicate that a "not-NULL"
> check should be added to the caller.
In my R_G_init.c, in function R_G_get_gisrc_file()
gisrc = G_store(G__get_gisrc_file());
where G__get_gisrc_file() is in my modified env.c:
char *G__get_gisrc_file (void)
FILE *fd;
if (!gisrc) {
fd = open_env("r");
if (fd == NULL) {
G_warning("Failure opening GISRC file");
G__set_gisrc_file(NULL);
return gisrc;
fclose(fd);
return gisrc;
and the original is:
return gisrc;
with:
static char *gisrc = NULL;
in both cases. Maybe it doesn't happen anywhere else, but I didn't expect
strlen() to be vulnerable - I thought it would give some sensible return
value (-1 is logical) when handed a NULL string.
Roger
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand at nhh.no
