[GRASS5] ANN: GRASS display with projection
Markus Neteler
neteler at itc.it
Tue Feb 18 12:42:06 EST 2003
Dear developers,
recently I received code from Beverly Wallace which allows to
display raster/vector/sites map projected in a GRASS monitor.
See details below, the C code is available in:
http://grass.itc.it/outgoing/
-> display_viewproj_src*
I tried it on Linux, it works as expected. Congrats to Beverly.
The limitation is that it currently uses an older version of
PROJ4 which is included and locally compiled.
Markus
PS: Here the announcement:
On Mon, Feb 03, 2003 at 04:57:59PM -0800, Wallace, Beverly T wrote:
> Markus,
> I have attached a gzipped tar file of the viewproj code. It includes a
> PROJ library (named differently from the GRASS version) and a proj.4 data
> directory that are needed by viewproj.
> To make it, run gmake5 from the LM directory. I tested it using GRASS
> 5.0.0 on a Sun with Solaris 8.
> Documentation is in viewproj/README. I will write html documentation soon.
> To demonstrate viewproj, if you have a lat/lon database with nations and
> coastlines data, then start a monitor and run the demo.viewproj.sh script.
> Please let me know if you have any questions or comments.
> <<LM.tar.gz>>
> Bev Wallace
> Lockheed Martin, Sunnyvale, CA, USA
> beverly.t.wallace at lmco.com
