[GRASS5] r.sun bug
Jaro Hofierka
hofierka at geomodel.sk
Fri Feb 21 07:54:50 EST 2003
Paul Kelly wrote:
>Hello
>The latest version of r.sun contains the inline keyword in front of 3
>function definitions in main.c . But as far as I can make out this is a
>C++ keyword and doesn't work in C. It won't compile on IRIX anyway. I had
>a look at this and thought seeing the aim is probably to make it run
>faster it could use macros instead.
>So the following patch seems to work and it still should run quickly. At
>least it compiles again anyway. But I can't really test it. If there are
>no objections I will add it to CVS in a day or two then.
Paul,
many thanks for the fix. I thinks it is a good solution. Please send me
a copy of the file, I'll try to test it a little bit.
Thanks,
Jaro
>Paul
>Index: local_proto.h
>RCS file: /grassrepository/grass/src/raster/r.sun/local_proto.h,v
>retrieving revision 1.2
>diff -u -r1.2 local_proto.h
>--- local_proto.h 19 Feb 2003 12:36:51 -0000 1.2
>+++ local_proto.h 21 Feb 2003 12:11:19 -0000
>@@ -1,8 +1,6 @@
> /* main.c */
> int INPUT(void);
> int OUTGR(void);
>-double amax1(double, double);
>-double amin1(double, double);
> int min(int, int);
> int max(int, int);
> void com_par(void);
>Index: main.c
>RCS file: /grassrepository/grass/src/raster/r.sun/main.c,v
>retrieving revision 1.8
>diff -u -r1.8 main.c
>--- main.c 19 Feb 2003 12:36:51 -0000 1.8
>+++ main.c 21 Feb 2003 12:11:19 -0000
>@@ -44,6 +44,10 @@
> #define DSKY 1.0
> #define DIST "1.0"
>+#define AMAX1(arg1, arg2) ((arg1) >= (arg2) ? (arg1) : (arg2))
>+#define AMIN1(arg1, arg2) ((arg1) <= (arg2) ? (arg1) : (arg2))
>+#define DISTANCE2(x00, y00) ((xx0 - x00)*(xx0 - x00) + (yy0 - y00)*(yy0 - y00))
> #include <stdio.h>
> #include <stdlib.h>
> #include <math.h>
>@@ -83,8 +87,6 @@
> int INPUT(void);
> int OUTGR(void);
> int min(int, int);
> int max(int, int);
> void com_par(void);
>@@ -99,7 +101,6 @@
> void line_x(int, int);
> void line_y(int, int);
> void cube(int, int);
>-double distance2(double, double);
> void (*func)(int, int);
> void calculate(void);
>@@ -133,36 +134,6 @@
> double cbh, cdh;
> double TOLER;
>-inline double amax1(arg1,arg2)
>- double arg1;
>- double arg2;
>- double res;
>- if (arg1>=arg2) {
>- res = arg1;
>- else {
>- res = arg2;
>- return res;
>-inline double amin1(arg1,arg2)
>- double arg1;
>- double arg2;
>- double res;
>- if (arg1<=arg2) {
>- res = arg1;
>- else {
>- res = arg2;
>- return res;
> int
> main(int argc, char *argv[])
>@@ -619,7 +590,7 @@
> for (j = 0; j < n; j++)
>- zmax = amax1(zmax,z[i][j]);
>+ zmax = AMAX1(zmax,z[i][j]);
> if ( o[i][j] != 0. ) {
> if( o[i][j] < 90. )
> o[i][j] = 90. - o[i][j];
>@@ -921,10 +892,10 @@
> ypom = lum_Ly * lum_Ly;
> pom = sqrt(xpom + ypom);
>- sr_min = amin1(sr_min,sunrise_time);
>- sr_max = amax1(sr_max,sunrise_time);
>- ss_min = amin1(ss_min,sunset_time);
>- ss_max = amax1(ss_max,sunset_time);
>+ sr_min = AMIN1(sr_min,sunrise_time);
>+ sr_max = AMAX1(sr_max,sunrise_time);
>+ ss_min = AMIN1(ss_min,sunset_time);
>+ ss_max = AMAX1(ss_max,sunset_time);
> if (fabs(pom) > EPS) {
> A0 = lum_Ly / pom;
>@@ -1207,7 +1178,7 @@
> if (dist > 1.0)
>- zp = amax1(c1,c2);
>+ zp = AMAX1(c1,c2);
> else
> func = NULL;
>@@ -1234,7 +1205,7 @@
> if (dist > 1.0)
> else
>@@ -1242,18 +1213,6 @@
>-inline double distance2(x00, y00)
>-double x00, y00;
>- double dx, dy;
>- dx = xx0 - x00; dx *= dx;
>- dy = yy0 - y00; dy *= dy;
>-/* return (sqrt(dx + dy));*/
>- return (dx + dy);
> void cube(jmin, imin)
> int jmin, imin;
>@@ -1268,14 +1227,14 @@
> y1 = (double)jmin * stepy;
> y2 = y1+stepy;
>- v[0] = distance2(x1, y1);
>+ v[0] = DISTANCE2(x1, y1);
> if(v[0]<vmin)
> ig=0;
> vmin=v[0];
>- v[1] = distance2(x2, y1);
>+ v[1] = DISTANCE2(x2, y1);
> if(v[1]<vmin)
>@@ -1283,14 +1242,14 @@
> vmin=v[1];
>- v[2] = distance2(x2, y2);
>+ v[2] = DISTANCE2(x2, y2);
> if(v[2]<vmin)
> ig=2;
> vmin=v[2];
>- v[3] = distance2(x1, y2);
>+ v[3] = DISTANCE2(x1, y2);
> if(v[3]<vmin)
> ig=3;
>@@ -1314,7 +1273,7 @@
> if (dist > 1.0) {
> for (i = 0; i < 4; i++) {
> if (c[i] != UNDEFZ) {
>- cmax = amax1(cmax,c[i]);
>+ cmax = AMAX1(cmax,c[i]);
> zp = cmax;
> else
>@@ -1454,18 +1413,18 @@
> slope = s[j][i] * DEG;
> if(linkein!=NULL) {
> linke = li[j][i];
>- li_max = amax1(li_max,linke);
>- li_min = amin1(li_min,linke);
>+ li_max = AMAX1(li_max,linke);
>+ li_min = AMIN1(li_min,linke);
> if (albedo != NULL) {
> alb = a[j][i];
>- al_max = amax1(al_max,alb);
>- al_min = amin1(al_min,alb);
>+ al_max = AMAX1(al_max,alb);
>+ al_min = AMIN1(al_min,alb);
> if (latin != NULL) {
> latitude = la[j][i];
>- la_max = amax1(la_max,latitude);
>- la_min = amin1(la_min,latitude);
>+ la_max = AMAX1(la_max,latitude);
>+ la_min = AMIN1(la_min,latitude);
> latitude = - latitude * DEG;
> if (latin == NULL && lt == NULL) {
>@@ -1498,14 +1457,14 @@
> exit(0);
> } else
> { /* ll projection */
> latitude = yp;
>_______________________________________________
>grass5 mailing list
>grass5 at grass.itc.it
>http://grass.itc.it/mailman/listinfo/grass5
