[GRASS5] v.digit color name mismatch
cheg01 at attbi.com
cheg01 at attbi.com
Mon Feb 24 00:59:49 EST 2003
I found the source of the incorrect behavior of the
v.digit->Customize->Color menu. The color names do not match the colors
used in the display fo the following reason:
The colors used in the display are defined in the file
<grass_dir>/src/include/colors.h:
#define D_COLOR_LIST:
"red,orange,yellow,green,blue,indigo,violet,white,black,gray,brown,magenta,
aqua,grey"
The color names used in v.digit are defined in the file
<grass_dir>/src/mapdev/v.digit/color.c:
static char *color_names[] = {
" white",
" black",
" yellow",
" blue",
" red",
" green",
" orange",
" grey",
" magenta",
" aqua",
" indigo",
" violet",
" brown",
To fix it, edit the color_names list to match the D_COLOR_LIST and
recompile v.digit.
