[GRASS5] various v.digit bug reports
cheg01 at attbi.com
cheg01 at attbi.com
Wed Feb 26 03:01:23 EST 2003
Several new bug reports on v.digit came up a few days ago:
#1676: Subject: Debug menu in v.digit
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: 5.0.1
The 'n - Display node info' option of the Debug menu in v.digit seems
inactive.
Aldo Clerici
This is true, the d_node_info code in lines 228-238 of debug.c does
nothing. Should probably drop the "n - Display node info" menu item from
the Debug menu.
#1674: Subject: Toolbox menu in v.digit
In the 'n - Display Node lines' option in the Toolbox menu of v.digit, the
functions of the middle (Next line) and right (Quit) buttons are inverted.
Aldo Clerici
It seems to be related to the following code:
In local_proto.h:
ifndef ANOTHER_BUTTON
# define MIDDLEB 2
# define RIGHTB 3
#else
# define MIDDLEB 3
# define RIGHTB 2
#endif
In mouse_yn.c
#ifdef ANOTHER_BUTTON
Write_base(14, " Middle: Quit") ;
Write_base(15, " Right: Next line") ;
#else
Write_base(14, " Middle: Next line") ;
Write_base(15, " Right: Quit") ;
#endif
In node_lines.c
Lines 59-77
next_line = map->Node[node_num].n_lines - 1;
Next = 3;
prev_line = 0;
first = 1;
do {
prev_line = next_line;
switch (Next) {
case 1: /* prev */
next_line = (next_line == 0 ?
map->Node[node_num].n_lines -1 : next_line-1);
break;
case 2: /* end */
/* shouldn't get here */
break;
case 3: /* next */
next_line = (next_line == map->Node[node_num].n_lines -1 ?
0 : next_line+1);
break;
and Lines 106-107
} while (2 != (Next = mouse_next_prev ("Select Next line:")));
display_line(map->Line[line_num].type, &Gpoints, line_num, map);
So if ANOTHER_BUTTON is defined:
right button=2, middle button=3
on the menu, middle button =quit, right button=next line
middle button increments and shows next line
right button exits loop
So if ANOTHER_BUTTON is not defined:
right button=3, middle button=2
on the menu, right button =quit, middle button=next line
right button increments and shows next line
middle button exits loop
I think the solution is to swap the contents of case 2 and 3 in the first
loop, change "Next=3" to "Next=2" at line 58 and change "2 !=" to "3 !=" at
line 106 of node_lines.c.
#1670: Subject: Color menu in v.digit
The color names reported in the right column of the Color Menu in v.digit
don't meet the colors displayed in the monitor.
Aldo Clerici
I found a solution to this a few days ago and I'm working on generating a
patch.
