[GRASS5] g3d notes and possible bugs
Glynn Clements glynn.clements at virgin.net
Wed Jan 8 22:35:40 EST 2003
John Harrop wrote:
> > Actually, the checks are there, but you have to explicitly choose
> > --with-glw and --with-motif (both are disabled by default).
> > The relevant make variables are:
> > XMINC
> > XMLIB
> > OPENGLwINC
> > LGLWM
> > AFAICT, the correct usage is:
> > EXTRA_CFLAGS = $(OPENGLwINC) $(OPENGLINC) $(XMINC) $(XCFLAGS)
> > OGLLIB       = $(LGLWM) $(OPENGLULIB) $(OPENGLLIB) $(XLIBPATH) $(XMLIB) $(XTLIB) $(XLIB) $(XEXTRALIBS)
> I thought I did the the same configure with both the release and exp
> sources.  Are the checks the same for both?
Yes.
Glynn Clements <glynn.clements at virgin.net>
