[GRASS5] configure and --with-gdal
Markus Neteler
neteler at itc.it
Tue Jan 14 13:12:37 EST 2003
just found a small inconsistency within 'configure':
configure --help | grep gdal
--with-gdal[=path] build directly against GDAL (path is gdal-config)
want's a path.
But it only works when specifying:
configure --with-gdal=/usr/local/bin/gdal-config
This is a file. Maybe we should modify 'configure[.in]' to
be happy just with
for consistency reasons (the other parameters are also pointing to paths).
Markus
