[GRASS5] (no subject)
Glynn Clements
glynn.clements at virgin.net
Mon Jan 27 19:50:03 EST 2003
zzzap at rakegroup.com wrote:
> Yesterday I updated by various source trees and NVIZ failed to compile in the
> HEAD branch (release is fine) because:
> buildInfxQry.o had not rule to make target.
> buildInfxQry.o and runInfxQry.o are part of PQ_OBJS= in Gmakefile.
> I think the Gmakefile needs to be fixed.
Did you run "make distclean" then re-run configure after updating?
Glynn Clements <glynn.clements at virgin.net>
