[GRASS5] [bug #1554] (grass) v.support
Request Tracker grass-bugs at intevation.de
Wed Jan 29 14:24:18 EST 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=1554
Subject:  v.support
Platform: GNU/Linux/i386
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.0
I think that the problem is that I'm using pre 5.0 data.  So when I try to run v.support I have the error.  It doesn't create topology for the data.  The following is what I get
GRASS:~>v.support sacnsurl
       V.SUPPORT:
Selected information from vector header
  Organization: Midwest ARcheological Center
  Map Name:  Survey coverage - lines
  Source Date:  10/94
  Orig. Scale:  -815988736
ERROR: region for current mapset is not set
    run "g.region"
GRASS:~>
I'm very new to GRASS and may simply be doing something wrong.  I appreciate any help here.
Molly Cannon
-------------------------------------------- Managed by Request Tracker
