[GRASS5] Almost there...
Glynn Clements glynn.clements at virgin.net
Fri Jan 31 22:00:05 EST 2003
Jeff D. Hamann wrote:
> I'm stuck on the following error (ignorance is such a drag and I've been
> scouring the Gmakefile trying to get this resolved to no avail since there
> doesn't seem to be a consistent way to generate a Gmakefile.
> gcc -O -o v.example OBJ.i686-pc-cygwin/main.o OBJ.i686-pc-cygwin/interface.o
> OBJ.i686-pc-cygwin/open_vect_in.o OBJ.i686-pc-cygwin/open_vect_out.o
> OBJ.i686-pc-cygwin/process.o       -lgis   -lvect -ldig2 -ldig_atts -lgis
> /usr/lib/gcc-lib/i686-pc-cygwin/3.2/../../../../i686-pc-cygwin/bin/ld:
> cannot find -lgis
There should be some -L switches there; at least one for the directory
containing the GRASS libraries.
> Here's the Gmakefile I've "stolen" from the web as well
> (http://www.geog.le.ac.uk/jwo/teaching/c_prog/14vector/index.html)
It appears to be somewhat out of date.
> LIBES = $(GISLIB) $(VASK) $(MATHLIB) $(VECTLIB) $(DIG_ATTLIB)
1. You don't need $(VASK) unless you're actually using that
functionality.
2. You probably do need $(XDRLIB).
> COMPILE_FLAGS = -O
Don't set this variable. If you really need any extra compile flags,
set EXTRA_CFLAGS instead.
> $(PROG): ${OBJ} ${LIBES}
>   ${CC} $(COMPILE_FLAGS) -o $@ ${OBJ} ${LIBES} ${LIBES}
1. This is a link command, and should use $(LDFLAGS), not
$(COMPILE_FLAGS), e.g.
$(BIN_CMD)/$(PGM): main.o  $(DEPLIBS)
	$(CC) $(LDFLAGS) -o $@ main.o $(LIBES) $(MATHLIB) $(XDRLIB)
2. Don't use $(LIBES) as a dependency; it will typically consist of -l
switches rather than pathnames. Each GRASS library has two variables
e.g. libgis has $(GISLIB) and $(DEPGISLIB); the latter is of a
suitable form for use as a dependency.
The best approach is to start with a Gmakefile from a similar module,
preferably one which uses the same libraries, and ideally one which is
under active development (so that the Gmakefile is more likely to be
up-to-date).
Glynn Clements <glynn.clements at virgin.net>
