[GRASS5] Re: compile error in splitfont.c in module for_grass
Martin Pokorny
martin at truffulatree.org
Mon Jul 7 12:46:18 EDT 2003
On Mon, 7 Jul 2003, Moritz Lennert wrote:
> I get the following error compiling GRASS5.0 CVS version:
> splitfont.c: In function `main': splitfont.c:132: unrecognizable
> insn: (insn 943 922 463 (set (reg/v:QI 63) (const_int 129 [0x81]))
> -1 (nil) (expr_list:REG_EQUAL (const_int 129 [0x81]) (nil)))
> splitfont.c:132: Internal compiler error in extract_insn, at
> recog.c:2148 Please submit a full bug report, with preprocessed
> source if appropriate. See <URL:http://gcc.gnu.org/bugs.html> for
> instructions. make[1]: *** [OBJ.i686-pc-linux-gnu/splitfont.o]
> Erreur 1 make[1]: Leaving directory
> `/data/GRASSCVS/grass/src/fonts/for_grass' GISGEN failure at STEP:
> src/fonts/for_grass
> Is this a gcc problem or a GRASS problem ?
I had the same problem when compiling with gcc-3.3 and gcc-3.2. I
guess that I could have tried some other gcc-3.x versions, but at this
point I just went back to gcc-2.95, and encountered no errors. That
would seem to point the finger at gcc.
Cheers,
Martin
Martin Pokorny
Tucson, AZ, USA
