[GRASS5] Re: proj bugs
H Bowman
hamish_nospam at yahoo.com
Thu Jul 17 00:00:18 EDT 2003
> I think the changes I made in the last few days may have fixed the
> biggest bugs in g.setproj. But you also need to check the generated
> DEFAULT_WIND file. It should have proj: 3 for lat/long and proj: 99 for
> nzmg or most projected systems (this determines the return value from
> G_projection() ).
[running 5.0 CVS from 2 weeks ago]
No, the DEFAULT_WIND file didn't update at all. starting with a ll
'proj: 3' location, running g.setproj to set a projection of nzmg, the
DEFAULT_WIND file is not touched (the file's time stamp is unchanged).
DEFAULT_WIND would need to translate n,s,e,w,e-w res,n-s res between
the DD:MM:SSh format and the UTM style ... slightly ugly.
I guess that has to be done if there is any change at all, even just
transform params. Maybe do it and dump the user into the set bounds/res
curses screen so they are forced to double check that the resolution
isn't now 23.456789m or something ... ?? more ugly.
Both PROJ_UNITS and PROJ_INFO are backed up to *~ and updated correctly.
While I can't imagine actually wanting to change type, someone undoubtedly
will try it, get stuck, and start filing bug reports....
Maybe just remove the ability to switch between proj types 1,2,3,4 with an
error message telling you to create a new location and use *.proj if you
want to do something that radical.
Another issue: can it list the transformation parameters without the user
having to type 'list' first[*], as there is no way to know which number
you want beforehand. Even if you remember what it was, it might change
without warning between versions. And if there is only one option just
use that with notification? (e.g. datum=wgs84, transform==1). Maybe not
if you want to parse the answer to the transform params question for
1, 3, or 7 inputs. [1 use the list, 3 or 7 prepend towgs84=]
... but maybe that is introducing too much complication.
Hamish
[*] e.g.
GRASS:~> g.setproj
Do you want to specify a map datum for this location?(y/n) [y]
Please specify datum name
Enter 'list' for the list of available datums
or 'custom' if you wish to enter custom parameters
Hit RETURN to cancel request
>nzgd49
Now select Datum Transformation Parameters
Enter 'list' to see the list of available Parameter sets
Enter the corresponding number, or <RETURN> to cancel request
>list
Number Details
1 Used in New Zealand
(PROJ.4 Params nadgrids=nzgd2kgrid0005.gsb)
LINZ NZGD49 NTv2 Distortion Model, accuracy approx. 10cm
2 Used in New Zealand
(PROJ.4 Params towgs84=59.47,-5.04,187.44,0.47,-0.1,1.024,-4.5993)
Accuracy approx. 4m
3 Used in Default nzgd49 region
(PROJ.4 Params towgs84=54.400,-20.100,183.100)
Default 3-Parameter Transformation
