[GRASS5] BWidget version problems
Martin Pokorny martin at truffulatree.org
Tue Jul 22 16:23:35 EDT 2003
I recently encountered some problems with the GRASS 5.1 dynamically
generated tcl command windows, which I traced to different versions of
the BWidget library installed on my system. My system's BWidget
library version is apparently not compatible with the GRASS code, to
the effect that when I issue a GRASS command from the command line
without arguments, I do not get a command window, but a 'wish' process
voraciously eats CPU cycles. Static GRASS GUI windows do not exhibit
the same problem. The difference is that the static windows require a
specific version of BWidget. The following cvs diff output shows a
solution to the problem.
cvs server: Diffing .
Index: parser.c
RCS file: /home/grass/grassrepository/grass51/lib/gis/parser.c,v
retrieving revision 1.22
diff -r1.22 parser.c
1029c1029
<     append(cmd, "package require BWidget\n");
>     append(cmd, "package require -exact BWidget 1.2.1\n");
Cheers,
  Martin
Martin Pokorny
Tucson, AZ, USA
