[GRASS5] [bug #2034] (grass) v.in.shape: ERROR: Polygon controller contained error.
Request Tracker
grass-bugs at intevation.de
Wed Jul 23 07:21:32 EDT 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=2034
Subject: v.in.shape: ERROR: Polygon controller contained error.
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
grass binary for platform: Compiled from Sources
GRASS Version: CVS_source snapshot 19 July 2003
v.in.shape from CVS source snapshot July 19 2003
Linux/i686/RedHat9
When running v.in.shape on a large-ish shape file (15mb), I get the
following error:
GRASS:~ > v.in.shape in=lake_poly.shp scale=50000 verbose=3
WARNING: Log file not specified. Sending messages to 'standard error'
File `lake_poly.shp' is of Type Area (Polygon) with 55721 entries.
Bounds:
W: 1093834.922949, E: 2088890.657221, S: 4749802.598574, N: 6191029.998727.
1186982.276431 4938013.152221
1186972.132724 4938030.668606
1186972.125677 4938035.477167
POLYGON (SHAPE) NUMBER 55716
Polygon contains 1 outer rings and a total of 0 holes.
An area point is supplied at 1187008.349075 | 4938058.613332.
No height co-ordinates are supplied for the vertices.
Main ring 1 has 0 holes
Shape No. 55717: Polygon Shape with 9350 vertices.
Part 1
1173392.346227 4941858.726825
1173391.861858 4941847.103953
1173391.282877 4941831.573488
1157434.648327 4944583.842922
1157437.859545 4944580.540597
1157445.987586 4944572.435234
1157448.195342 4944570.133572
1157453.814728 4944564.529865
1157461.630670 4944564.640992
1157463.534588 4944564.643652
Part 29
FATAL ERROR: There was a problem importing the map.
GRASS: ~>
That's about 1200 vertices into Shape #55717; one of the previous
Shapes in the same file had over 2300 verticies and worked ok.
plently of memory and disk space to spare.
If I try v.support on the partial result, I get thousands of
"PNT_TO_AREA failed:" errors, sequentially up to Category 55716.
input file(s) or further tests available upon request.
thanks,
Hamish
hamish_nospam @@ yahoo.com
-------------------------------------------- Managed by Request Tracker
