[GRASS5] GRASS5.1: compile problem - cannot find -lgrass_gis
Moritz Lennert mlennert at club.worldonline.be
Wed Jul 23 08:54:44 EDT 2003
Hello all,
Trying to compile todays CVS version of 5.1 (using todays CVS version fo
5.0 for mix), I get the following error during make:
make[4]: Entering directory `/data/GRASSCVS/grass51/lib/db/sqlp/test'
gcc -I/usr/include/ -I/usr/local/include/ -g -Wall  -Wall  -I/usr/include/
-I/usr/local/include/ -I/data/GRASSCVS/grass51/include
-I/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/include  -L/usr/lib/
-L/usr/local/lib -L/data/GRASSCVS/grass51/dist.i686-pc-linux-gnu/lib
-L/usr/lib/ -L/usr/local/lib -o sqlptest sqlptest.c  -lgrass_sqlp
-lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime     -lm
-lz
/data/GRASSCVS/grass51/include/gis.h:36: warning: `GRASS_copyright'
defined but not used
/data/GRASSCVS/grass51/include/sqlp.h:145: warning: `newNode' declared
`static' but never defined
/usr/bin/ld: ne peut trouver -lgrass_gis (translation: "/usr/bin/ld:
cannot find -lgrass_gis")
collect2: ld returned 1 exit status
make[4]: *** [sqlptest] Erreur 1
Can someone help me with this ?
Also, I don't know if this test is really necessary for running 5.1, so
couldn't compilation continue even if this fails ?
Moritz
