[GRASS5] Applicant for developing
Radim Blazek blazek at itc.it
Tue Jul 29 05:51:21 EDT 2003
On Monday 28 July 2003 19:38, Thierry Laronde wrote:
> Please don't take anything as an "attack" ---since I know how poorly
> rewarding the work for open source/free software might be, with people
> always critizing.
Attacks are welcome. You must expect counter-attack, but what I see
below is not realy attack, you have to learn more about GRASS to find
our real weaknesses.
> My point of view is probably limited, indeed perhaps narrow, but I
> prefer a clean solution to a "popular" one.
Do you prefer clean solution as programmer only or also as user?
It is nice to have clean solution, but if you cannot work with
dirty data all others are producing? I don't want to make
GRASS "example reference GIS application following GIS theory of '80s",
(even if it probably looks like that), it should be also possible to
use it for real work.
> My definition of "open" is
> also narrow: what must be open is the door to let me escape with my
> data. If I have means to import a standard format and to export to a
> standard format without loosing the added value I have worked on, for me
> the software is correct
Currently the standard de facto is shapefile (very similar to SFS)
and it is impossible for example, to import overlapping areas from
shapefile. Topological format is good only for areas in 2D,
once you have more dimensions (z, time) you are lost.
We have to prove to model overlapping areas in topological
format (at least for limited number of overlapping areas)
or to add a new type for polygon to GRASS format.
Radim
