[GRASS5] Update for Spearfish sample data
Markus Neteler
neteler at itc.it
Wed Jun 4 04:13:34 EDT 2003
On Mon, May 12, 2003 at 09:33:24AM +0100, Paul Kelly wrote:
> On Fri, 9 May 2003, Markus Neteler wrote:
> > The updated package is here:
> > http://mpa.itc.it/markus/tmp/spearfish_grass50data.tar.gz
> > please
> > - try with any 5.0.x
> > - try on various platforms
> > You may simply run
> > g.region -l
> > which uses PROJ4 to report the current region in Lat/Long coordinates.
> > If reports are ok, I'll move the file to
> > http://grass.itc.it/data.html
Are there objections to update the spearfish_grass50data.tar.gz file?
If not, I'll replace the old version with wrong datum.
Markus
