[GRASS5] grass.itc.it: up again - IP traffic restrictions
Bernhard Reiter bernhard at intevation.de
Thu Jun 5 06:28:39 EDT 2003
Markus,
thanks to you and ITC-irst
for the continuing efforts to host GRASS.
	Bernhard
On Wed, Jun 04, 2003 at 11:32:35AM +0200, Markus Neteler wrote:
> The main site 'grass.itc.it' is up again - the provider
> has resolved the network problems.
> Some changes:
> As the internet traffic consumed nearly all bandwidth of
> our institute, we have activated "apache-throttle" to keep
> the maximum traffic below a certain limit over a given period.
> If you get a message:
>   "503 - Service temporarily not available"
> the server is overloaded. Please use a mirror site close to you.
> Probably the "throttle" parameters have to be tuned in a few days.
> The current policy is:
> - allow 1 Mbit/4sec in general, otherwise "sleep" two seconds
> - allow 500Kbit/2sec per IP, otherwise "sleep" two seconds
> We have to see how to treat short peaks.
> Mirroring with rsync - changes:
> Also the mirror sites will be reorganized to use cascaded mirroring.
> rsync connections to grass.itc.it will be only allowed for a few
> mirror sites. These mirror sites will provide rsync access for
> other mirrors and third party connections.
> All changes are needed to reduce the network load here at ITC-irst.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030605/2cdcf6fd/attachment.bin
