[GRASS5] [bug #1926] (grass) Compilation error in function main
Request Tracker
grass-bugs at intevation.de
Fri Jun 6 09:38:29 EDT 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=1926
Subject: Compilation error in function main
make[2]: Entering in directory `/root/Grass5/grass51_exp_2003_05_31/vector/v.
in.
ogr'
gcc -g -O2 -Wall -I/root/Grass5/grass51_exp_2003_05_31/include
-I/root/Grass5/
grass51_exp_2003_05_31/dist.i686-pc-linux-gnu/include -I/usr/local/include
-DUS
E_GDAL_H -I/usr/local/pgsql/include/
ude -I/root/Grass5/grass51_exp_2003_05_31/dist.i686-pc-linux-gnu/include \
-o OBJ.i686-pc-linux-gnu/geom.o -c geom.c
/root/Grass5/grass51_exp_2003_05_31/include/gis.h:36: warning:
`GRASS_copyright'
defined but not used
-I/root/Grass5/
-DUS
-o OBJ.i686-pc-linux-gnu/main.o -c main.c
main.c: In function `main':
main.c:142: `wkbLinearRing' undeclared (first use in this function)
main.c:142: (Each undeclared identifier is reported only once
main.c:142: for each function it appears in.)
/usr/include/ctype.h: At top level:
`GRASS_copyright'
make[2]: ** [OBJ.i686-pc-linux-gnu/main.o] Erro 1
make[2]: Saindo do diretório `/root/Grass5/grass51_exp_2003_05_31/vector/v.in.
og
r'
make[1]: ** [subdirs] Error 1
make[1]: Saindo do diretório `/root/Grass5/grass51_exp_2003_05_31/vector'
make: ** [default] Error 1
-------------------------------------------- Managed by Request Tracker
