[GRASS5] Minor problem with 5.0.2 on Solaris X86
cheg01 at attbi.com
cheg01 at attbi.com
Sun Jun 8 19:15:11 EDT 2003
I just built Grass 5.0.2 from source on a laptop running Solaris 9 x86
using gcc 2.95.3 from the Solaris companion CD.
I disabled fftw, odbc, and opengl for this machine. The only issue was:
/src/display/devices/PNGdriver/Gmakefile needs an "-lm" tacked on the $(CC)
command line
The configuration was a bit complicated because the Solaris companion CD
installs everything under /opt/sfw instead of /usr/local. How do you
specify more than one "--with-includes=" directory for configure?
