[GRASS5] r.terraflow not found...
Laura I. Toma
laura at cs.duke.edu
Mon Jun 9 20:22:45 EDT 2003
It is easy to compile r.terraflow. Go in the r.terraflow directory
<grass-src-dir>/src.contrib/DUKE/r.terraflow
and run bin/gmake5
This should compile two executables, r.terraflow and r.terraflow.short and
place them in
<grass-src-dir>/dist.<platform>/etc/bin/cmd/
To see them from grass5 you copy them to (or make symbolic links)
<grass-dir>/bin/grass5/
Check out also http://www.cs.duke.edu/geo*/terraflow/
Let me know if you have troubles.
-Laura
On Mon, 9 Jun 2003, Helena wrote:
> Glynn Clements wrote:
> > Jeff D. Hamann wrote:
> The new version that compiles under gcc3.2 is at
> http://www.cs.duke.edu/~laura/bin/
> I did not have time to try it out and submit it,
> so if you can test this latest version that would help. Also, let us
> know if you
> have any questions - it is still a work in progress.
> Glynn is right that it belongs to the GRASS development version and
> the previous version of r.terraflow is in src.contrib/DUKE
> Helena
> > > I've recently stumbled across r.terraflow while performing google searches
> > > and it sounds like the tool I'm looking for right now. When I tried to find
> > > the command in the latest and greatest GRASS dist (cygwin 5.0.2), couldn't
> > > find it. At least not in the binary dist.
> > > Is it in there?
> > It isn't in the 5.0.2 binary packages. The source code is in the 5.0.2
> > source packages and the CVS release branch, but the build system
> > doesn't have the necessary extensions.
> > Whereas the rest of GRASS is written in C, r.terraflow is written in
> > C++. This required some extensions to the build system; in turn, it
> > was decided (by me, primarily) that this was too controversial for
> > 5.0.2 (i.e. the small risk of breaking everything outweighed the
> > benefits of one additional module).
> > If you want r.terraflow, you can either try building it manually (i.e.
> > hacking src/CMD/*) from the 5.0.2 source, or obtain the development
> > version from CVS (which has the necessary changes to configure etc;
> > you have to specify the --with-cxx switch in order for r.terraflow to
> > be built).
> > Glynn Clements <glynn.clements at virgin.net>
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
