[GRASS5] [bug #1947] (grass) d.scale documentation out-of-date
Request Tracker grass-bugs at intevation.de
Sat Jun 14 15:09:12 EDT 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=1947
Subject: d.scale documentation out-of-date
Platform: WindowsNT/2000/XP
grass obtained from: Trento Italy site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.0.2
On-line documentation for d.scale incorrectly describes the at= option of d.scale.
Incorect (re-typed by hand):
at = x,y The map easting (x) and northing (y) geographic coordinates des-
         ignating the location at which the upper left corner of the scale
         is to be placed.  The user should choose geographic coordinates
         located within the current geographic region (see d.where and g.region
         for these coordinates).
         Default: 0.0,0.0
Better (My interpretation):
at = x, y The display coordinates designating the location at which the upper
          left corner of the scale is to be placed.  Each edge of the display
          is divided into 100 units, with 0.0,0.0 being the upper left corner        and 100.0,100.0 being the lower right corner of the display.
          Default (0.0, 0.0)
David Finlayson
dfinlays at u.washington.edu
-------------------------------------------- Managed by Request Tracker
