[GRASS5] grass51: value of $(GDALLIBS) in a Makefile
Aleksey Naumov
naumov at acsu.buffalo.edu
Sun Jun 15 17:11:21 EDT 2003
Yaro,
Is your libgdal.1.1.so in the library search path (in $LD_LIBRARY_PATH or
directory where it is listed in /etc/ld.so.conf (then you also have to do
/sbin/ldconfig))? I also had to add a link to my libgdal.1.1.so:
libgdal.so -> libgdal.1.1.so, in order for the -lgdal linking flag to work.
Aleksey
On Sunday 15 June 2003 03:02 pm, Jaro Hofierka wrote:
> Hi,
> I am having the similar problem in v.in.ogr (even with -with-gdal option):
> make[2]: Entering directory
> `/home/grass/grass51_exp_2003_06_07/vector/v.in.ogr'
> main.c: In function `main':
> main.c:142: `wkbLinearRing' undeclared (first use in this function)
> main.c:142: (Each undeclared identifier is reported only once
> main.c:142: for each function it appears in.)
> main.c:52: warning: `Ogr_layer' might be used uninitialized in this
> function
> main.c: At top level:
> /home/grass/grass51_exp_2003_06_07/include/gis.h:36: warning:
> `GRASS_copyright' defined but not used
> make[2]: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
> make[2]: Leaving directory
> make[1]: *** [subdirs] Error 1
> make[1]: Leaving directory `/home/grass/grass51_exp_2003_06_07/vector'
> make: *** [default] Error 1
> Moreover, v.out.ogr compiled OK but it doesn't work:
> GRASS 5.1.0-cvs:~ > v.out.ogr
> v.out.ogr: error while loading shared libraries: libgdal.1.1.so: cannot
> open shared object file: No such file or directory
> Jaro
> Paul Kelly wrote:
> > On Sat, 14 Jun 2003, Aleksey Naumov wrote:
> >>Hi,
> >>I noticed this when compilation got to v.out.ogr, it compained about
> >>unresolved OGR* symbols. This is due to wrong definition of GDALLIBS in
> >>Platform.make -- here's what it has:
> > You need to use the --with-gdal option with the configure script. I will
> > look at making this the default for 5.1
> > Paul
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
> grass5 mailing list
Aleksey Naumov
GIS Analyst
Center for Health and Social Research
Buffalo State College
