[GRASS5] [bug #1962] (grass) lcc projection in g.setproj
Request Tracker grass-bugs at intevation.de
Tue Jun 24 05:28:37 EDT 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=1962
Subject: lcc projection in g.setproj
g.setproj (relevant code also in src/libes/gis/geo_init.c) does not
prompt correctly for the standard parallels in the Lambert Conformal
Conic (lcc) projection.
Should be EITHER one central parallel (lat_1) OR
first and second parallels (lat_0 and lat_2)
Markus asked me to fix this but I don't think it's trivial and it may
be better to wait until g.setproj is re-written. Prompting for the
necessary parameters for each projection is really something PROJ.4 should
do but as far as I can see it doesn't. The parameters should however
be in a data file and not hardcoded into src/libes/gis/geo_init.c and
src/include/geo.h I think (although this was probably a nice tidy
solution back in the early 90s when GRASS only supported the few
projections that are used in the State Plane system).
Paul
-------------------------------------------- Managed by Request Tracker
