[GRASS5] Multiuser grass projects
Stephan Holl
sholl at gmx.net
Fri Jun 27 01:54:00 EDT 2003
Hello Glynn, John
At Fri, 27 Jun 2003 00:10:11 +0100 Glynn Clements wrote:
> However, you would then need to find
> some other way to prevent one user from modifying a mapset which
> another is using (e.g. change $GISBASE/etc/Init.sh to create the lock
> file in the mapset directory instead of the user's home directory).
I have a modified Init.sh, which allows concurrent use with one user
(e.g. apache-user). Every session has its own mapset, where .grassrc5
and .gislock are stored in the mapset-dir.
I could provide it, if you like.
cheers
Stephan
Stephan Holl
GnuPG Key-ID: 11946A09
07:52:09 up 26 min, 1 user, load average: 0.00, 0.07, 0.13
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030627/8b341d0b/attachment.bin
