[GRASS5] Re: [GRASSLIST:5692] GRASSLIST:5691] Re: Unrectified DXF importation
Markus Neteler neteler at itc.it
Sat Mar 1 10:36:56 EST 2003
[moved here from GRASSLIST]
Should we change v.support to always perform the '-r'
to avoid below problems?
Markus
On Fri, Feb 28, 2003 at 05:10:23PM +0800, Dr. Mohamad Firuz Ramli wrote:
> Dear Radim
> Thanks for the tip. It's works now.
> Regards
> Firuz
> On Friday 28 February 2003 08:42 am, Dr. Mohamad Firuz Ramli wrote:
> > v.transform in=vmap_roadxy out=vmap_roadtrans point=roadgcp
> > The map is transformed with the residual value
> > Transformation is complete
> > v.support vmap_roadtrans
> Try v.support -r map=vmap_roadtrans
> > g.region -p vect=vmap_roadtrans
> > However, it shows that the region of vmap_roadtrans is similar
> > to the one that of original or unrectified.
> > However,  I tried
> > d.vect vmap_roadtrans
> > but nothing coming out.
> Radim
