[GRASS5] r.in.gdal updates?
Markus Neteler
neteler at itc.it
Thu Mar 13 07:49:46 EST 2003
On Mon, Mar 10, 2003 at 10:01:18AM -0500, Frank Warmerdam wrote:
> Markus Neteler wrote:
> >>>>Outstanding
> >>>> - fix the grey color tables issue for RGB maps
> I think Glynn is referring to the fact that GDAL doesn't return the
> real dynamic range of the original sensor. For instance, an 11bit sensor
> would be represented via GDAL as 16 bit (depending on the format it is
> stored in of course), not 11. So, of course GDAL returns information on
> the data type but GDAL can't transport the meaningful dynamic range of
> the original sensor since that isn't even available in most formats.
> In short, if it is GDB_Byte assume a dynamic range of 0-255 otherwise the
> data should be sampled.
So far I have added a test for GDT_Byte:
if yes, then
G_make_grey_scale_colors (&colors, 0, 255);
is applied to the channel. The resulting color file contains then
% 0 255
0:0 255:255
Also I have added GDALGetColorInterpretationName() to write out
channel.Red, channel.Green, channel.Blue
instead of
channel.1, channel.2, channel.3
in case of a multi-channel image. This works as for 'gdalinfo'.
- tested with GeoTIFF RGB. -> channel.Red etc..
- tested with GeoTIFF Palette -> channel
- tested with LANDSAT 7 CEOS -> channel
- tested with LANDSAT 7 FAST -> channel.1, channel.2 ...
(if ColorInterpretationName == Undefined, the channel number is used)
Outstanding issue:
The CELL compression - I don't know how to apply that suggestion
(Eric ?).
Please update directly in CVS if required.
Markus
