[GRASS5] Autoconf problems, Grass 5.1 solaris 8 sparc
Glynn Clements glynn.clements at virgin.net
Sat Mar 15 15:32:32 EST 2003
cheg01 at attbi.com wrote:
> I decided to enable everything in the configure script and I cannot get 3
> of the optional libraries to work.
Look in error.log. In all three cases, the problem is almost certainly
because the library which is being checked requires some other library
which configure hasn't been told about.
Glynn Clements <glynn.clements at virgin.net>
