[GRASS5] d.path and building 5.1
Buchan Milne
bgmilne at cae.co.za
Wed Mar 19 08:06:39 EST 2003
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Firstly, is there any documentation available on d.path? I would like to
make use of it ...
Secondly, to use d.path, I am trying to build grass51 from source (have
the binary builds but some relocation errors on certain tools), and seem
to be running into some problems that no-one else is having.
I got
http://grass.itc.it/grass51/source/snapshot/grass51src_cvs_snapshot_exp_2003_03_15.tar.gz
and
http://grass.itc.it/grass5/source/snapshot_experimental/grass50src_cvs_snapshot_exp_2003_03_15.tar.gz
I untarred them side-by-side, and ran:
$ ./configure --with-dbm-includes=/usr/include/gdbm/
- --with-postgres-includes='/usr/include/pgsql
/usr/include/pgsql/internal' --with-nls --with-blas --with-lapack
- --with-freetype --with-freetype-includes=/usr/include/freetype2/
- --with-motif --with-motif-includes=/usr/X11R6/include --with-dbm
--with-glw --with-gdal
- --with-grass50=/home/bgmilne/rpm/BUILD/grass50_exp_2003_03_15/
$ make mix
$ make
And then after about 2 minutes of compiling, I get this error:
make[2]: Entering directory
`/home/bgmilne/rpm/BUILD/grass51_exp_2003_03_15/lib/gis'
gcc -g -O2 -Wall
- -I/home/bgmilne/rpm/BUILD/grass51_exp_2003_03_15/include
-I/home/bgmilne/rpm/BUILD/grass51_exp_2003_03_15/dist.i686-pc-linux-gnu/include
-o OBJ.i686-pc-linux-gnu/adj_cellhd.o -c adj_cellhd.c
adj_cellhd.c: In function `G_adjust_Cell_head':
adj_cellhd.c:44: `PACKAGE' undeclared (first use in this function)
adj_cellhd.c:44: (Each undeclared identifier is reported only once
adj_cellhd.c:44: for each function it appears in.)
If I touch the target file, I get similar errors on many more sources.
Am I doing something wrong, or should I update to cvs?
(I also ran configure - with similar arguments - and make in the grass50
directory after the first failure, and tried again, but that did not help).
Regards,
Buchan
Buchan Milne Mechanical Engineer, Network Manager
Cellphone * Work +27 82 472 2231 * +27 21 8828820x121
Stellenbosch Automotive Engineering http://www.cae.co.za
GPG Key http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.1 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE+eGtfrJK6UGDSBKcRAo8YAJ9zHYGlDzF4KVOaeYQDaLFxkwHdvwCbBkUT
JCN79j9SNkmFcHckTLCy/yo=
=Rfpl
-----END PGP SIGNATURE-----
