[GRASS5] d.barscale, d.grid minor changes
Markus Neteler
neteler at itc.it
Mon Mar 24 11:51:43 EST 2003
two minor changes:
d.barscale: -t prints the scale text on top rather than
to the right
-f is fixed, now works
d.grid: - optionally a simple colored border with
distance tick marks can be printed at the map
border
- grid and border ticks can be switched on/off
as desired by the user.
Due to the restrictions of the display system
the border ticks are not looking exciting yet. Also
I observed the bug that, depending on the
aspect/height ratio of the GRASS monitor either
the bottom line or right line which surrounds the
map when using the border ticks is not visible.
Maybe my fault, maybe a 1 pixel offset somewhere in
the display driver?
Here an example:
(120kb)
http://mpa.itc.it/markus/tmp/dgridbarscale.jpg
Cheers
Markus
