[GRASS5] [bug #1766] (grass) v.out.e00 inconsistency
Request Tracker
grass-bugs at intevation.de
Thu Mar 27 09:58:15 EST 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=1766
Subject: v.out.e00 inconsistency
v.out.e00 does not work with binary vector files outside the current mapset
e. g. when in mapset andreas, v.out.e00 input=test at PERMANENT output=test.e00
does not work. This is in accordance with the user manual, which states the
mapset=... parameter. But this is inconsistent.
tcltkgrass has no enty field for input of mapset= parameter.
I'll look into this another time.
Andreas
-------------------------------------------- Managed by Request Tracker
