[GRASS5] [bug #1837] (grass) redhat-9 incompataibility with all versions of grass5.x.x.x
Glynn Clements glynn.clements at virgin.net
Thu May 1 07:32:35 EDT 2003
Request Tracker wrote:
> Subject: redhat-9 incompataibility with all versions of grass5.x.x.x
> grass-5.0.0
> configure: error: *** Unable to locate PostgreSQL includes.
> grass-5.0.1
Both of these versions used an "internal" PostgreSQL header which, for
later versions of PostgreSQL, required that you add an additional
directory to the --with-postgres-includes= switch.
This dependency has been removed in 5.0.2. And both 5.0.0 and 5.0.1
can be compiled *if* you use the correct configure switches.
> grass-5.0.2
> ./configure:
> checking for SQLConnect in -lodbc... yes
> checking whether to use FFTW... yes
> checking for location of FFTW includes...
> checking for fftw.h... no
> checking for dfftw.h... no
> configure: error: *** Unable to locate FFTW includes.
Do you have FFTW installed? If not, either install it, or use
--without-fftw (this will disable i.fft, i.zc, i.shape and
r.surf.fractal, all of which need the FFTW library).
> grass-5.0.2
> precompiled for linux:
> GRASS:~ > d.mon start=x1
> ERROR: In main.c: Couldn't get socket path.
> Failed to get socket name for monitor <x1>.
> Problem selecting x1. Will try once more
It's hard to be sure why this is happenning, but possible reasons are
if GRASS is unable to determine your username, or if it can't create
the directory /tmp/grass-<username>, or if the directory exists but it
can't set the permissions correctly.
> grass-5.1.0
5.1 is a development version, and should be considered "alpha".
> GRASS 5.1.0-cvs:~ > Error in startup script: ps.map: error while loading shared libraries: libpq.so.2: cannot open shared object file: No such file or directory
Either you don't have the PostgreSQL client library, or you don't have
a version which is compatible with the pre-compiled binary package.
Glynn Clements <glynn.clements at virgin.net>
