[GRASS5] problem with G_get_null_value_row &/or mapset searches in my own program
Scott W Mitchell smitch at mac.com
Sat May 3 15:06:33 EDT 2003
cflow sounds like a good tool to know about, thanks.  I hadn't got to
checking whether or not those functions were even called.
My guess is that I've abused a pointer somewhere, or am somehow else
tramping on memory, leading to a misleading error.
I'll have to comb through my assignments looking for mistakes.
Thanks...
Scott
On Saturday, May 3, 2003, at 04:29 Canada/Eastern, Roger Bivand wrote:
> On Sat, 3 May 2003, Glynn Clements wrote:
>> Scott W Mitchell wrote:
>>> I've compared my program to others in the source tree, and as far as
>>> I
>>> can see I am using it identically.  So I got it into a debugger and
>>> found that the core dump is actually happening "further in", when
>>> G_get_cell_hd calls G_is_reclass ...
>> I don't see how G_get_null_value_row() can end up calling
>> G_get_cellhd().
> As far as I can see using cflow (an old but trusted utility for
> printing a
> graph of a function's call hierarchy) G_get_null_value_row() does not
> call
> G_get_cellhd(), nor do any of the functions called by it all the way
> through its call hierarchy.
> Although this isn't relevant here, Markus did ask me to remind him
> about
> cflow, which, since it comes from the same era as much of the code (at
> least in libes/gis), does show what is calling what, or what is called
> by
> what if inverted.
> Roger
> Roger Bivand
> Economic Geography Section, Department of Economics, Norwegian School
> of
> Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
> Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
> e-mail: Roger.Bivand at nhh.no
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Scott W. Mitchell						smitch at geog.utoronto.ca
Department of Geography					Phone: (613) 730-5375
University of Toronto at Mississauga	UTM fax: (905) 828-5273
3359 Mississauga Road					Local fax (613) 822-5143
Mississauga, ON L5L 1C6					Canada
